| Probably can't hold oil and is leaking down or it's not getting oil to it. Check your oil level. Burp the coolant system with the heater on full. I would ensure your oil level is correct, and run it for a bit. See if it gets better. If not you might need to swap the lifter out. It's not a knock though, so cross it off your list.
